Can West System 423 Graphite Powder be used with MAS Epoxie? What mix 10%?
RE: Graphite
Is the graphite just one coat after filling the weave?
How best to fil the weave if you know from the start you are going to have a graphite bottom?
Epoxy only; Lightweight Epoxy and micro- ballon mix; or epoxy and graphite?
What about also adding Colloidal Silica to the graphite for hardness?.
-Ivan
RE: Graphite
1. No. Ususally 2 or 3 coats, depending on how much graphite you add and how thick the coats are.
2. Epoxy/microballoon mix.
3. Some people do that and think it's great. I never felt the need, probably because I paddle over muddy/sandy bottoms. If it was rocky, I might try it, too. But don't be afraid to experiment.
RE: Graphite
» Submitted by Laszlo - Tue, 9/16/14 » 6:53 AM
Yes.
Depends. The more graphite, the slipperier the boat bottom. The less graphite, the harder the boat bottom.
For rocky river bottoms, 10% is good. For sandy river bottoms with occasional rocks and shells, 50% is good.
Pick a value that seems a good match for your paddling area and try it out for a season. Next season, if it didn't work out, it'll be easy to reapply a different mix.
Have fun,
