I've done the fillets and taping on my WD12 and it will be ready for a second coat of epoxy tomorrow. Is the second coat just to fill the weave or do I recoat everything? Should I sand at all? I do have some puddles and drips. Also, what's thicker, catsup or mustard? In the manual, it uses both as examples of consistency. I always thought they were about the same.
Tom
RE: Epoxy second coat
If it was me, I would add the fill coats till you get full coverage and not risk sanding into the cloth. Once you have good coverage, then I would sand the drips/runs/ whatever.
As to which is thicker, I guess that would depend on the brand. I've had some pretty runny mustard, and I play heck getting the ketchup out of that damn bottle!
But in your case, I would say mustard.
Thanks for the info. Next question, what do I do about these jaggies?
http://web.me.com/tomtom/Site/Kayak.html#27
I wish I would have run the cloth all the way up the side instead of following the manual. Will a couple more coats of epoxy cover that up or at least make it less noticeable? If I sand it down will it turn white and stay white?
So... what did you do about your jaggies? I have the same problem and I see from your pics that you've cleaned them up nicely.
John
» Submitted by MrKim - Mon, 11/24/08 » 11:16 PM
3 light coats all over.
I would sand out the puddles and drips. Or scrape or dremel....
Mustard
