Due to adding some 'art' which starts on the deck and runs over to the side hull, I would like to glass the hull after the deck is attached. Any problems delaying the hull glassing?
I can't see any problem with it. I think the main reason for glassing the hull first is to protect it from getting scraped up and stained during the rest of the building process. I think a layer of fiberglass on the inside of the hull should be good enough to keep the hull as stiff as you would want it.
RE: Attaching deck
» Submitted by Casey Wilkinson - Sun, November 23 » 8:16 PM
