Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
[Note to all: I posted this earlier on the for sale section, but am reposting here for builder viewing.] I am doing the build in garage thing, and am at the final deck varnishing stage. Unfortunately where I am the forecasts are not much above 40 during the next 14 days, and plenty of mid-20s in the evenings. I have a small heater/fan, but am mindful of the dust advice, and know that the garage even with sweepings and rinsings is still a dustbowl. So, if I go ahead and varnish (Interlux Schooner) will it not cure properly, or should I just give it extra time between coats. Wanna gittur dun! Thanks!
5 replies:
RE: November Varnishing
50 degrees is the posted minimum temp. I would not expect desirable results from my boat and finishing job being exposed to 20 degree temps. Best time to do this is early Spring before the pollen is flying around. The fumes from this stuff is intense, even wearing a respirator, which you will be wearing, you need some sort of ventilation, even if your garage is a 2 car garage.
hello i have kind of the same problem you may want to try getting a long portible electric base heater . place it in side the boat . an other product maybe japan dryer that you could put in the varnish to help speed up the drying . i my self would try the heater if i had one i wound up bringing the boat in the house .
I would stay away from using a space heater. Varnish has far too many phenols in it and the vapors in a closed space could be a fire hazard. Wait until spring. If your November temps, like mine, are in the 30's and 40's, you're not paddling until April anyway... so what's the rush? My kayak is on hold until March/April... I plan on doing prepwork this winter, but won't touch epoxy or paint/varnish until spring. My $0.02. ~Chris
Here in Alaska we would have about a 1 month building season if we waited for spring. Why not use the good ole clamp lights to warm up the project? We had two setup in the shop about 40F and it brought the surface temp up to 80F. No fan to create dust either. This is my plan for the winter, is there a problem with that?
» Submitted by kayakkev - Wed, November 19 » 9:48 PM
You can contact http://www.yachtpaint.com/usa/default.asp and ask them. They answered me in less than 24 hours with every question I had for them. GREAT customer service, and the makers of Interlux.
