Link to current Kakolo 14 Build
Hello all,
I’m currently building a Kaholo 14 and posting the build on my blog. For any who are interested here’s the link.
http://stufffromtheshop.blogspot.com
RE: Link to current Kakolo 14 Build
I am 90% done a 14 from plans so only about 80% of the work to do - I will post the results and a few build pics soon. I would have done a blog but so many others like you have demonstarted the right way to build a kaholo - my blog may have been a dmonstration of things not to do....
Nick from Novs Scotia
newtosup,
Thanks on the tailblock. I'm fortuate to have a large heated place to work...makes life a whole lot easier. Best of luck on your build...stickynick too.
While we are talking about tailblocks I figured I'd post a link to mine. I have the hull and deck both fiberglassed but no fill coats.
http://i558.photobucket.com/albums/ss27/firstlight10/Work/73F8B09F-4D3D-42A2-AD88-0DD9C224437F_zpsocuax0qa.jpg
Its Ipe and Purpleheart ripped into 1/4" strips. Before fiberglassing I sanded to 220 grit then wiped it with denatured alcohol to remove sanding dust. I hope the color stays the same once fill coats and varnish are applied as I am very happy with the colors.
» Submitted by NewtoSUP - Fri, 4/4/14 » 7:40 PM
Thanks for sharing Steve, beautiful tailblock design!
I am doing a 12-6 from plans, but I am currently on hold as its too cold in my shop to do the fill coats effectievly. I don't have a blog but plan to do a wrap up post on here once its finished this summer.
