Fineline Tape
After two paint stores and two big boxes without luck at finding 3M Fineline, I rolled the dice and tried Shurtape Razor Edge Gold.  Worked like a charm.  I rolled it out with a rubber roller along the edge and backed it up away from the edge with blue tape and had no leaks.  It is said to be 60 day tape, but I would not want to push it.  Had it on over a week however through many coats and wet sandings.
 FWIW, looks like a good alternative.
RE: Fineline Tape
Auto body supply stores carry it. If you need it in the future try one if you have one in your area.
