Need a 1/8 drill bit with 3/8 countersink. Where to buy?
As part of my Chester yawl build< I need a 1/8" drill bit with 3/8" countersink. This is new to me.
Having trouble finding it without buying a set, Went to Home Depot and local hardware store with no luck. Any suggestions.
Also, some places list sizes in numbers such as size 10. Anyone know the equivalent to 1/8"?
Thanks in advance for any help.
RichMPL
RE: Need a 1/8 drill bit with 3/8 countersink. Where to buy?
Previous advice would be for counterbore (flat bottom, round head screw) vs.countersink (tapered, flat head screw). Most hardware stores sell a 3 pack of countersink bits for less than the cost of a single forstner bit. If you cant get the right drill/countersink combo, you can get a countersink bit which will drill a tapered countersink on top of your 1/8" hole. Screw dimensions can be referenced at the link below- it sounds like your 1/8 screw is equivalent to a #4 size screw.:
Thanks HShanley for your helpful response. I really appreciate it
.RichMPL
» Submitted by TinWhiskers - Wed, 3/6/13 » 11:27 PM
With all the trouble wouldn't it be easier to get a 1/8 bit and a 3/8 forstner bit? Two gallons of gas you wasted could have been spent on tools. While yer at it get a 3/8 dowel to cap the screw hole.
Km
