Contemplating about which way to tie together the bottom panels of my Duckling (8 footer)---start at the ends or start at the middle and work outward or inward. I have already finished, but thinking about which is the "accepted" or "correct" way to do this ...
RE: stitchening panels
Don't stress over this part. I put the panels flat together, so you can align them, then wired them not too tight.
Then open them out like a book, and all will come into shape. Here is my Duckling at this stage.
For a cunning way to do this single handedly to get the bulkheads in, sandwich the panels between two clamps, and gently press into the correct angle. This is a Shearwater Sport Hybrid:
I hope you're still monitoring the Forum. How did you manage to get your Duckling hull panels and temporary forms stitched without a large gap? From what I can see, you didn't add any holes.
» Submitted by HShanley - Wed, 2/6/13 » 10:11 PM
On my 2 17LTs I started at the bow and worked back. I think you'd always want to start at the bow as this allows you to set the panel alignment for a good looking bow- the way the 17's stern comes together it's a small matter to correct misalignment with a jigsaw or sander but that could get ugly if attempted at the bow.
if you start in the middle you could misalign BOTH ends.. Then you'd be looking at a Viking Funeral.
