puzzle joints
I am buildind a woodduck 10, and just glued the puzzle joints, they seemed to be fine but when i checked them after hardening the underside on some did not match completely, i can feel a ridge where they join. Is this something that can be sanded out or should i try to reset them?thanks dave
RE: puzzle joints
If the ridge is greater than the thickness of the veneer you could sand them smooth.  If it's greater than that, you can hit them with a heat gun/blow dryer and reset the joint.
RE: puzzle joints
*** I meant LESS than the thickness of the veneer***
