Epoxy cure question
I am doing the rub rail scarf joints for the Chester Yawl.  CLC manual says 24 hrs. at 75 degrees.
Since my basement is 60 or so, I hung lights over the joints bringing the temp. to 75-80.  These will be on for 8 hrs.
My questuion is if I turn off the lights overnight and joints cool to 60 room temp,, should I turn them on again in the morning  or just finish the cure at 60 degrees?
If I leave them at 60, roughly how much more time will it take for the cure?
Thanks for any help.
Rich MPL
1 reply:
RE: Epoxy cure question
You will find that if your work area is low humity and a stable temp of 64+
degrees your cure will be fine.  I am building now in an area of that temp and it is cure to tough within 8 hrs and I let it cure 36 hrs before I sand and recoat.
