Epoxy question for 17lt hull glass
Hey all!! Getting ready to glass and epoxy my hull. I was wondering how long do I have to re apply the the second coat of epoxy without having to sand using Mass? I ask because of my work schedule, I'll have to wait around 24hrs between coats. I assume there is no way to sand after the first coat with all the weave showing if you wait to long. Thanks, Justin
RE: Epoxy question for 17lt hull glass
Without sanding 24 hours at 70 degrees is about the longest. I usually sand between coats, just wait a little longer and vacuum up all of the dust so that you don't get white spots.
