Depends on how bad it's scuffed up. Usually just a light wet sanding with 320 is fine followed by one, two at the most, coats of varnish. The bottom may be a little worse so maybe an extra coat of varnish but the way I look at it nobody really sees the bottom anyway!
~ The step-by-step instructions in the manual along with the photos made this project easy to follow comfortably with basic woodworking knowledge. ~ more
RE: Refinishing a wood duck
» Submitted by George K - Fri, 10/26/12 » 9:52 PM
George K
