Thanks for response-only trouble is i already put one coat of unthickened epoxy into entire cockpit area. there was no guidance regarding this in manuel or in video. anyway ,is that a major problem ? will the glass still adhere? i just put this coat on this morning so it is still sticky. maybe i should put the 'cockpit glass in now? does it matter?
Thanks, Michael
1 reply:
RE: chris-re:clc17 kayak
» Submitted by Chris J. - Mon, 9/1/08 » 11:49 AM
You'd have a hard time getting the cloth smooth over a sticky surface...but it's not a big deal - just give it a couple of days to fully cure then sand it with some 150 grit paper, vacuum and wipe down with damp paper towel. Let dry fully then continue with laying the cloth and adding a couple of fill coats.
