So I am about to varnish my rails and LO and BEHOLD! There is a drip of brightsides paint I failed to notice cured on the soon to be beautified wood. What is the best way to remove this problem or am I doomed to have a spotted rail?
Also, do people generally varnish the underside of the rail? I'm not sure its necessary...
1 reply:
RE: Paint Varnish Question
» Submitted by George K - Wed, 5/23/12 » 2:20 PM
If you have a coat of epoxy on the rails it's no big deal at all. Simply do a light sanding and the paint should come right off. If the rails were bare wood when you painted and you got paint on them it's a bit harder to get rid of the paint. It'll take a bit more sanding but the good news is the mahogany is dense enough paint doesn't penetrate too far. You could use a paint remover in the affected spot but there's a good likelihood you'll also remove some paint where you'd like to keep it. And, yes, the underside of the rails are also varnished.
George K
