How to protect boat until Fall painting?
I have just completed an Oxford Shell kit to the point where I am sanding the epoxy coating prior to varnishing and painting.
Although I had been fully prepared to start priming and painting the hull and varnishing the deck, the temporal proximity to the end of summer is now staring me in the face.  I now want to get some rowing done before I have to resume classes this fall, and waiting a week or more for the paint to cure seems too long.
From reading many posts, it seems clear that using the boat with just the epoxy coating is in itself not a problem.  I gather that the primary issues I would be facing by employing a non-varnished/painted boat lie in the lack of UV protection.
Is this correct?  Is the primary hazard to an unfinished hull the possibility of sun damage?
Further, I would very much appreciate any advice on the subject of minimal protection for a month's worth of boating.  For instance, applying a single coat of varnish or something along these lines; might this provide short term protection?
Thanks very much for any advice,
molecularstork
5 replies:
RE: How to protect boat until Fall painting?
I used my Wood Duck for 3 months just epoxied with no problems. My wife's CH16LT went 6 months without varnish. And I have a 6 year old pirogue that's yet to be varnished or painted.
As you say, the main problem is the UV exposure yellowing and breaking down the epoxy. The way you get by without varnish is to sand off the degraded outer layer of epoxy and replace it with fresh before the damage gets all the way down to the wood.
The amount of damage is determined by the amount of sunlight exposure. In the tropics, it takes about 5 years of daily exposure to completely destroy the epoxy layer. So if you keep the boat in a dark place while you're not using it and don't take it out too often, you can limit the damage to the outermost layer which will have to be sanded off and re-applied anyway because of all the scratches, dings and dirt you'll be getting from normal use.
So take it out and have fun. Find out what needs to be changed before you get the coffee table finish on it.
Thanks very much for the excellent experience-based reply Laszlo.   That I can take the boat out and have fun is what I was most hoping to read.
I have something to add to Laszlo's comments.  What he said is true, but I wanted to add something else I have seen happen.  I had a customer bring me a boat that they had used for a few months with just an epoxy finish on it.  They wanted me to varnish the boat.  When I took off the deck rigging I noticed that there were pale lines on the deck where the bungies had been laying.  This makes me think that even though the epoxy is not getting damaged, the sun is still having an effect on the epoxy, making it turn darker.  I have seen this more than once and living in Seattle, the sun is not exactly tropical.
That will happen even with 5 coats of quality marine varnish applied.....
