I'm getting closer to starting my build and I'm looking for a rabbeting bit for my router. I have a 1/4" and 1/2" chucks on my routers. It's kind of confusing because different manufactuers refer to the dimensions differently. Thought I'd get a recommendation from someone. Thanks - Tim
5 replies:
RE: Rabbeting bit recommendation?
Hi
I'm not quite sure what you'd like to rabbet. If it is cove and bead strips I've found after some research a company delivering these bits with a 1/2" shaft.
www.toolstoday.com in the States has a flute and bead set-The item code of it is 54176. The price for was US$ 54.56 (without shipment) in February 2010, shipment to Euope was $ 11.50.
Tim,
Doesn't matter what the shank size is, either the 1/4" collet or the 1/2" collet will work. The important thing is to get the right rabbetting bit. The width will be spelled out for you, i.e., 3/8", 1/2", etc. The depth is set by your router. Some bits come as a set, that is one cutter and several different sizes of bearings you put on to change the width of the rabbet. Rockler has a good selection as does MLCS Woodworking. Hopes this helps.
George K
If you are building the dory, I found the required bit but it needed modification of the plate. I think it would have been easier to use a guide. I can give you more info if you want.
The set with the bearings I highly recommend. MCLS stands behind there products as well. I had a problem with a keyhole bit. It broke almost immediately in some very hard wood. Contacted MCLS, they replaced it with no question.
» Submitted by ludwigd - Wed, 4/11/12 » 10:50 PM
If you are referring to the bit shaft diameters, those are standard dimensions. If doing heavy work, go with the 1/2" shaft.
