Fiberglass visible after sanding
OK. I have sanded the epoxy smooth to get ready for varnish (wood duck). There are several spots where the fiberglass is visible, but still smooth. When I wipe the dust off with denatured alcohol and it is wet you cannot see the fiberglass. When it flashes off you see the weave again. It seems like I read somewhere that this would be OK to varnish. Not looking forward to another coat of epoxy and more sanding. I suppose I'll try a small test section with varnish to see if the weave pattern disappears. But, if anyone has gone through this before it would be helpful.
Andy
RE: Fiberglass visible after sanding
As long as you have not actually sanded into the cloth, and it feels smooth, it will disappear when you varnish. -Wes
» Submitted by Beaker - Fri, 2/17/12 » 2:23 PM
I had the same on my wood duckling. It varnished out ok for me.
