Foam Roller Covers- cut in half
The CLC decsciption of these yellow covers includes-
"Sold in pairs. Cut each roller in half and use on a small roller frame."
Anyone have a recommendation for the best way to cut 'em inhalf without wrecking them?
Thanks,
Isaac
5 replies:
RE: Foam Roller Covers- cut in half
 Hey Isaac,
 I just use a japanese pull saw but someone may have a better way. Also if you get the 9" rollers you can cut them into 3 pieces and use the 3"roller frame.
I just use a box cutter. Stab one spot and roll the roller.
You can just buy a 3" roller frame with 3" foam rollers if you are lazy.
Thanks much for the ideas.  So, now I know there is no special Acme brand foam roller cover cutter.
Cheers
