So I may have made a mistake...I applied what I thought was a thin coating of prekote two days ago and today tried to sand. It took A LOT of sanding and many discs to remove perhaps 60% of it...In this situation do I just keep sanding and hope for the best? What did I do wrong?
RE: too much primer?
» Submitted by jimcav - Thu, 12/15/11 » 7:52 PM
You don't have to sand most/all of the primer off. Just sand until you have a nice smooth surface. What grit sand paper are you using?
