Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Small Patch of fiberglass cloth showing through!
On my 17LT, built in 2007, I now have two spots (each spot only 1" in diameter) on the hull where I can see the weave of the glass. It isn't super obvious and can only be seen if the boat is on the roof rack in bright sunlight. I can't feel the glass. There is definitely epoxy over it and at least 6 coats or varnish. Is it possible to sand down those spots and add more epoxy to cover the weave, then rebuild my finish layers? Thanks! Tim Clark
1 reply:
RE: Small Patch of fiberglass cloth showing through!
» Submitted by Chris J. - Tue, August 5 » 3:00 PM
Tim...I had the same situation last year....here are the replies from the archives: http://www.clcboats.com/forum/archives/thread/85694.html
I just left mine alone. You really can't se them unless the light is just right and you tilt your head a certain way!
Take care.
Chris
