Light epoxy coat pre-glassing ?
When I built my SW S&G the instructions suggetsed using a roller to put a very light coat of epoxy down prior to glassing the deck. I am getting ready to glass the deck of my NH hybird and wondred if I should do that. The benefit I see is that the epoxy would fill small indentions, cracks, etc. that might later develop air pockets under the glass.
Thanks, Mark
RE: Light epoxy coat pre-glassing ?
Absolutly! A light coat of epoxy on the raw wood before glassing will fill the grain of the wood fairly well - which will result in a much better application of the glass.
Just leave it until it is just touch-dry before applying the glass, usually only a couple of hours.
I did that for my first S&G boat but no my last 4 boats and have had no problems. The trick is to make sure that there are no indentations, cracks, etc. before applying the glass. That can be done with a snader, some epoxy/woodflour putty and a putty knife.
The reason I don't do it is time and weight. In the time that it takes to precoat and wait until it cures enough to apply the glass, I can apply the glass and the first fill coat.The weight aspect is that unless you are careful with the precoat, you could add excessive epoxy and increase the weight. Not by much, but some people are obsessive about sanding and varnishing, I'm odd about minimizing weight and epoxy consumption.
So it's up to you how you go. Both work and both have their advantages
Have fun,
I will think about both ideas and decide which will work best for this build. Still 105 degress where I am at so I have time to think about it, can't really do  any epoxy work in this heat. It does give me time to fill every little crack and dent becuase I can't do much else yet. That may be my answer. Thanks !
Mark
