went 3-D on the Kaholo today
My daughter is excited! A few mods to the CLC plan - mainly layoput on plywood. I scarfed two 3mm sheets and laid the deck and both side panels out. Then when I cut them I did not need to scarf pieces together, like those skinny sides with no real referance line.  Since the front pieces of the bottom overlap those have to be pieced. It all fit on three 4x8 sheets, and you do not need a 2X8 6mm chunk of ply to do the frames and stringers. I used about half of a 2x8.
« Previous Post     List of Posts     Next Post »
