Installing the coaming soon. The instruction say to glue up all the pieces directly on the boat. I am considering gluing up the spacers & coaming seperately, on a flat surface, then gluing the assembly to to boat. Has anyone done it this way? I'm thinking that it might be easier to remove glue drips, and sand the outside edge, off the boat, where I don't have to worry about scrathing the hull as much. On the other hand, will I be able to get it to clamp to the boat, or do the parts need to be able to slide around on one another to get it to conform?
11 replies:
RE: Shearwater Cockpit Coaming
Thank you Wes. I have referred to your "Shearwater Construction Notes" frequently, and found some good tips. I glued the hatch spacers to the hatch rims seperately, and followed your advice for the fiberglass cutting.
On my first Shearwater I glued the whole thing down at once. On the second one I put plastic on the deck and glued the spacers and coaming together while clamping the assembly to the deck. I then lifted it off and was able to sand the spacers easily. I then glued it onto the deck. This worked out really well.
What Dan said. Here's how I did it on my WD12:
and here's how it turned out:
Note the properly formed curve built into the coaming. And here it is being finally assembled onto the boat:
Doing it this way does indeed make the sanding and glue drip cleanup infinitely easier, as well as preserving the deck from scratches. While this is a WD12 instead of a Shearwater, the principle is identical for both boats.
Or, you can glue down the spacers first, take care of sanding and skim-coating them, then glue the coaming. I found this way to be more manageable than trying to keep the whole stack of parts aligned. I wouldn't worry too much about the outside of the spacers. They're pretty well hidden under the shadow of the coaming.
Cheers, Pat
Thanks, Laslo, it seems to be working perfectly. Sanding the outside of the coaming spacers was a breeze.
I ran veneer around the inside & outside spacers of the coaming to hide the laminations on my Shearwater.
Lew
Jim,
You're quite welcome (but remember, you heard it from Dan first).
Ken,
Absolutely yes.
Laszlo,
You're a gentleman and a scholar. I hope to see you again at Okoumefest
» Submitted by twofootartist - Mon, 4/4/11 » 8:15 AM
Don't do it! The coaming on the Shearwater is not flat. Glue the whole assembly onto the boat in one operation. Have 15-20 of Home Depot's 99-cent spring clamps on hand. Once you get it all together, you have time to make minor adjustments. Then clean up as much excess epoxy as you can before it hardens. See photos and more ideas on the Shearwater, Merganser, and Ganymede pages on my blog site www.twofootartist.com
-Wes
