Gear | Boat Plans | Supplies | | Books/DVDs | Kayaks | |
| Forum Guidelines | Builders' Forum | |
Greetings Checking on install of the cam buckles. Can I epoxy the buckles to the sheer clamp without problems. Looks at though I would have no problem removing the seats if the webbing ran through the epoxied buckles. If I have to place the buckles on the webbing then screw through the webbing into the sheer clamp I would have to remove the seats by removing the screws on the seats themselves, thereby leaving the webbing in the MC. Anyone come across this, or am I over reacting to an obvious solution. Thanks for your input. Rod
RE: Cam Buckles MC 16.5
Try again with a smaller picture.....
Maybe a link would be better.... http://www.flickr.com/photos/algonquinpaddler/2662773620/sizes/l/
Chris Thanks for input. My buckles are a one piece not quick release. webbing in and through with a clip you lift up to tighten webbing. Both ends the same. Rod
» Submitted by Chris J. - Sat, July 12 » 8:39 PM
Rod...if your cam buckles are in two pieces you can install as per the photo below. One length for the seat and one length for the sheer clamp. Then you just have to unbuckle to remove the seat. It's also fully adjustable.
Chris
