Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Prepping for Varnishing Cockpit
Before the summer gets too far along, I have to varnish the cockpit of our MC16.5. I applied 6 oz. 'glass under 2 coats of epoxy to the entire area so the weave is not entirely filled and there is a nice texture that I want to maintain for a bit of traction. How should I go about prepping the area? I thought I would just sand it and then varnish...but with the texture, sanding won't be entirely complete with the slight dimples in the 'glass...will the varnish adhere adequately? Thanks Chris
1 reply:
RE: Prepping for Varnishing Cockpit
» Submitted by spinnb7 - Tue, July 8 » 1:02 PM
what i just learned about varnishing the cockpit is that when you go to glue in the foam seat, the contact cement and the varnish do not play nice together. i just scraped up a bunch of varnish that bubbled and peeled from the cockpit. i know i cannot be the first person to do this, what a suprise!
