Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Accidentally mixed slow and medium hardener. Any ideas?
I used up the original jug of slow hardener and had to order more. CLC was out of the slow and sent me the medium hardener. As I started to run out of the small bottle of medium I wasnt thinking and combined the 2 jugs and put a coat on the hull bottom. Any ideas if this will be a disaster?
RE: Accidentally mixed slow and medium hardener. Any ideas?
Don't worry. as earlier answer providing same brand. I add combo quite often. can really help in fair weather. painters have been doing it for years. good luck
In fact, that's the only way to make medium hardener for Silvertip - mix equal parts fast & slow. Laszlo
Gosh, I do that all the time ON PURPOSE. With the MAS brand, you can mix hardeners willy-nilly for a custom cure time. As long as the ratio of resin to hardener (two-to-one) never waivers, you're good with any blend of hardener.
» Submitted by Julie K - Sat, September 4 » 4:51 PM
not a problem, assuming that it is all the same *brand.* The only thing that changes is cure time -- In fact, one can intentionally mix two different speed hardeners (e.g. fast/slow) to change the cure time.
Here's the FAQ on the Mas epoxy website that discusses that:
http://www.masepoxies.com/Epoxy_School_/Tech_Support_FAQ.html##24
Julie K.
