I have an older ch17 it has ware at each end, has anybody glassed in a piece of rope to prevent hull damage?The upright stiffener next to the seat is cracked loose.should i remove it seal everything and re attach?or will a fillet over the joint seal it watertight?one more quicky the top deck has a few small bare spots can i just varnish or do i need to seal with epoxy first?the top is clear bottom is white
