Refinishing old Cheasapeake LT 17
All,
 I have a ten year old LT 17 that I need to refinish prior to this season. Over the past season the finish has really gone over the edge and needs some help.
How should I prep for a new coat(s) of varnish? I would appreciate anyones assistance in step by step recommendations to include grit of sandpaper.
Thank you in advance, Shannon
RE: Refinishing old Cheasapeake LT 17
If you don't have any gouges, just wet sand the old varnish off with #440 and re-apply 3 to 5 coats of new varnish, wet sanding between coats.
If you have some especially nasty gouges even after the wet sanding, roll on a new coat of epoxy over the gouges, sand it smooth with #220, and re-apply 3 to 5 coats of new varnish.
It's just the same thing you did 10 years ago.
