DO NOT EVER USE THIS JUNK. Blem has made a resonably good 1st attempt at boat building into a horrible experiance. I have had to remove the 3 coats of interlux because of the blushing issue but the worst part is the amount of sanding required becuse this junk won't flow out!
Beware, and stay with MAS.
1 reply:
RE: Blem White resin
» Submitted by PocketShip - Tue, 6/1/10 » 2:12 PM
I'm sorry to hear about your experience with Blehm resin. I had never heard of them before. Was it their surface coat resin or laminating resin that you used?
www.blehmplastics.com
