113. Coating the Bench with Epoxy
Because coating, sanding, and finishing will be difficult once the bench is installed, it will be sealed with epoxy and sanded all of the way to 220-grit, ready for varnish, BEFORE it's installed in the boat. Here, the underside is receiving the first coat of epoxy.
