Gear | Boat Plans | Supplies | | Books/DVDs | Kayaks | |
| Forum Guidelines | Builders' Forum | |
I am ready to install the beam just aft of the forward bulkhead. The bulkhead is set bat 48" and the beam is to go at 60 3/8" from the most forward point. When I pull a string line from the forward stem ( point ) to the center top of the beam, the top of the bulkhead is down about 1". as best as I can tell from the pictures, the bulkhead should be on the same plane as the beam. What's up? Tom tobadick@verizon.net
