Wood Duck - no end pour
Posted by Laszlo on Feb 27, 2008
Here's a shot of my Wood Duck 12 with a stem piece in lieu of an end pour. It's made of 4 pieces of scrap wood (an old chunk of 2x4 and a piece of orange crate), very roughly shaped and bedded into a stiff epoxy/woodflour putty. The shot also shows the tacks between the wires which will hold the hull together after the wires are removed and before the seams are taped.
The pros - 3 oz of epoxy instead of 8, the wood only weighs 3.5 oz. Wood is less brittle than epoxy, no dams, no epoxy boil-overs, no standing the boat on end. The wood also provides a larger gluing surface than just a fillet.
The cons - need to hand shape the wood pieces. This is mitigated by using mutiple pieces of wood and by the gap-filling qualities of the putty.
While the endpour method described in the manual works very well and is probably the most reliable for beginners, piecing together a stem requires no special skills or great workmanship and yields a lighter boat.
Submitted for your consideration,
- Re: Wood Duck - no end po by Chris J. on Feb 27, 2008
Re: Wood Duck - no end po by Laszlo on Feb 27, 2008
- Re: Wood Duck - no end po by chris on Feb 27, 2008
- Re: Wood Duck - no end po by Laszlo on Feb 27, 2008
