Re: Tape residue removal
Posted by Jim E on Feb 23, 2008
It's best not to experiment with random sovents on your pride and joy. Even if they leave the finish alone, you can get the dreaded fisheyes when you put the next coat of varnish on. Alcohol should do it, with a bit of rubbing. It's safe on epoxy and varnish, too. Also cheap.
In Response to: Re: Tape residue removal by David Warren on Feb 22, 2008
- Re: Tape residue removal by Tony F on Feb 24, 2008
