Re: Skerry mast.
Posted by john millar on Feb 15, 2008
I forgot to mention. I went boomless with "Ruddy Duck" so don't have the gooseneck/boom snapping problem. With a little parafin or candle wax at the partners, it pivots right around. In the old days, they would use tallow or grease. I understand CLC needs to make a kit that is easy to build for the masses, and making a square peg fit a square hole is easy and cheap.I have not tried the stock Skerry mast set-up, and am sure it works O K, I do know the rotating mast works great. John
In Response to: Re: Skerry mast. by CLC on Feb 14, 2008
- Re: Skerry mast. by Christine DeMerchant on Feb 20, 2008
