San O beveling keel line
Posted by James Abell on Jan 15, 2008
Hi, Ive got to 'slightly bevel' the keel line, to give the keel line joint tighter.
How much should I bevel in? 45 degrees from out surface?
Also, when I glue the sheer clamps to side panels, how much thickened glue should I put on it for optimum strength, 1/2 mm each gluing area?
Many Thanks.
http://www.paddleboardingscotland.com
- Re: San O beveling keel l by George K on Jan 15, 2008
