Feathercraft rudder
Posted by theo on Jan 10, 2008
After skimming through Kayaks You Can Build I'm not sure now that I have all the parts, I have the basic narrow blade K1 unit, cables and clamps and cable housing and hangers, nuts,bolts, washers, I took a look at the book again and I'm lead to believe the metal gudgeon is a custom fabrication and that most rudders are simply hung in a hole drilled in the endpour, True?
- Re: Feathercraft rudder by Dick on Jan 16, 2008
- Re: Feathercraft rudder by theo on Jan 17, 2008
