Re: Prosthetic for a rudd
Posted by don foote on Dec 21, 2007
What you need is a rudder that will be, mathematically, the right size for the sailrig. If you know what the size is that you need, you could expand the search and look at other small boats besides kayaks (opti's, hobie, whatever). There are a ton of small craft out there so it is likely that a rudder could be found that what satisfy your you said, no need to reinvent the wheel....
In Response to: Re: Prosthetic for a rudd by dusty yevsky on Dec 21, 2007
