Re: Clc 16 San O
Posted by Camper on Nov 29, 2007
If I recall correctly, I kept garage above 40 F (4 Celsius.) at first because it was the minimum per the manufacturer. But I learned that 50 F (8 Celsius) was better. At 40 the cures are slow.
Regardless, the resin and hardener should be at room temperature or warmer when mixing. Do not try to use them at workshop temperature, too thick.
In Response to: Clc 16 San O by James Abell on Nov 29, 2007
- Re: Clc 16 San O by James Abell on Nov 30, 2007
- Re: Clc 16 San O by Jim E on Dec 1, 2007
