Re: Strongback Question
Posted by CLC on Nov 26, 2007
Our strip kits use a plywood box-beam internal strongback. The box beam is stiffer and immune to warping. We use AC fir plywood for the box beams, with CNC-machined rabbeted corners.
I've done strip boats both ways. The compelling advantage of the internal stringer is that you can turn it every which way on the sawhorses.
In Response to: Strongback Question by Matt on Nov 25, 2007
- Re: Strongback Question by Kurt Maurer on Nov 26, 2007
Re: Using Strongback by Dave Kennedy on Nov 26, 2007
- Re: Using Strongback by Matt on Nov 26, 2007
- Strongback for S&G by Kurt Maurer on Nov 26, 2007
- Paging Kurt Vonnegut...er by Robert N Pruden on Dec 4, 2007
