Re: MC16 carlins
Posted by Chris J. on Nov 25, 2007
Gary...if you clamp them up in this fashion, they should pull straight and your nose block will sit fine. I did have about an eighth of an inch under-hang on my coaming at the carlin bottom edge where it finally met the "V" at the nose block but you can't see it and it tapers off to nothing a short ways back. The coaming bottom becomes flush with the bottom edge of the carlin.
Chris
http://farm3.static.flickr.com/2194/1762888520_6ff7c0001b.jpg
In Response to: MC16 carlins by Gary O. on Nov 25, 2007
