Re: wood duck tack weld
Posted by Ralph on Nov 23, 2007
If I understand where you are, i.e. going to tack weld the sheer to the top deck & sides to the hull bottom, there is no big rush when you tack them. I had plenty of time, but it was only about 70 F.
Also you only need one layer of tape (I put mine on the hull). My fit wasn't perfect and will require some sanding/plane work later.
In Response to: wood duck tack weld by chris on Nov 22, 2007
