Re: When to Paint?
Posted by Petewp on Nov 7, 2007
Dont paint until the end. If this were a motorcycle - ok with all those nitty grtty things you cant reach unless you disassemble then fine. A kayak is just so much simpler than that. Too, i would never paint something first [like the deck] then bend it to shape. You are just stressing the paint which will result in cracks and peels. Just do it after its all assembled.
The obvious amendment to this is when you epoxy under the decks before installing for obvious reasons.
In Response to: When to Paint? by MarkS on Nov 2, 2007
