Re: SnowBear trailer
Posted by theo on Oct 22, 2007
I've had thoughts about getting someone to weld/fabricate a bar with rollers that can be mounted up the same way the end gates are hung, so my heavier boat doesn't catch the keel on the end of the center metal panel. By-the-by I'll wet the rubber but NEVER wet the rims as I figure this is not a boat trailer thus the wheel bearings should not get wetted. With so many boat trailers anouncing their presence with growling bearings as they pass; No, keep my axle well away from the water, thankyouverymuch. On the other hand there's, http://www.rackandroll.com/ I've been tempted...just not cheap.
In Response to: SnowBear trailer by Ron Paro on Oct 18, 2007
