Re: Shearwater builders
Posted by Darryl on Oct 21, 2007
No shear clamps on the non-strip Shearwater. I D-F-D'd, siliconed, & installed the machine screws CLC recommends and did add a small washer inside the boat. Use a dremel to cut off the screw flush with the self-locking nut so you won't snag your gear. You also can just D-F all your holes prior to any epoxying or fiberglassing but not necessary.
In Response to: Shearwater builders by David S. on Oct 19, 2007
- Re: Shearwater builders by Jim E on Oct 21, 2007
