Re: MC13 Deck Install
Posted by Chris J. on Oct 18, 2007
Mike....the only additional thought when cutting the joint is the position of the utility blade. I find if you hold the knife at a very slight angle(see inset joint cross section below)you'll get a very clean and tight joint. If you let the blade wobble as you pull the cut, you'll see less that perfect results once the epoxy seeps into the end grain.
In Response to: Re: MC13 Deck Install by Kyle Lindstrom on Oct 17, 2007
