Re: I got a few answers..
Posted by LeeG on Oct 11, 2007
If that line 'most of the strength is from the glass and epoxy, the wood is mainly there as a form' then everyone paddling a Chesapeake with a glass on only one side of the deck or exterior of the compartment hull panels is in trouble. Anyone who's used the boats knows the plywood is strong and glass isn't required everywhere,,but if it's not on some panels it's a problem. It's not that critical on the inside of the side panels as it is on the bottom, etc. I've wondered if there's an optimum wood/glass ratio for durability/weight. I think someone did some tests with strip panels that showed a bit more glass with a bit less wood worked out well but it required more labor for minimal return so simply using regular weave 6oz worked. When in doubt make some test panels or test joints and break them up. Not rocket science although it's surprising how poorly carbon cloth does compared to glass or s-glass.
In Response to: Re: I got a few answers.. by Camper on Oct 11, 2007
- Re: I got a few answers.. by Ask Dr. Kayak on Oct 11, 2007
- Re: I got a few answers.. by LeeG on Oct 11, 2007
- Strength Test Results by Robert N Pruden on Oct 12, 2007
- Some Engineering Data by Robert N Pruden on Oct 12, 2007
Re: Strength Test Results by Camper on Oct 12, 2007
- Re: Strength Test Results by Robert N Pruden on Oct 12, 2007
- Re: Strength Test Results by Camper on Oct 13, 2007
