Re: Duck Picture
Posted by Laszlo on Oct 9, 2007
Leroy,
32 x 100 inches, give or take a couple of inches. The cardboard box is somewhat inaccessible at the moment so that's the best measurement I could get. If you need exact, check with CLC.
There are 4 molds total for the hull. The second from the back is permanent and becomes the only bulkhead in the boat. The rest are temporary. It's because of all that open space in the bow and the large cockpit opening that CLC recommends the float bags. A spray skirt would help, too. Those should be available next week or so from CLC.
There is a single aft compartment with a hatch on it. Some kind of hatch is required to allow access to the inside while taping on the deck.
Hope this helps. There'll be more pictures and text on my website shortly.
In Response to: Re: Duck Picture by LeRoy on Oct 9, 2007
