Re: Paint &varnish questi
Posted by Bob Santore on Oct 9, 2007
I would varnish first and wrap around the sheer a little. When finished varnishing (and fully cured) tape to mask for painting, scuff the varnish that is showing and paint to the masked edge.
This way, you only have to mask when painting, and you won't have to worry about the edge at all when varnishing. If you accidentally (or on purpose) get some varnish on the part of the hull you intend to paint, it's not a big deal because the paint will cover it easily. Not so easy to get varnish to cover paint - you have to remove all trace of paint first.
In Response to: Paint &varnish question by Kyle Lindstrom on Oct 9, 2007
- Re: Paint &varnish questi by Kyle Lindstrom on Oct 9, 2007
You really don't by Charlie Jones on Oct 9, 2007
- Re: You really don't by Kyle Lindstrom on Oct 10, 2007
- I use at LEAST two by Charlie Jones on Oct 10, 2007
- Re: I use at LEAST two by Kyle Lindstrom on Oct 10, 2007
- Ususally a small amount by Charlie Jones on Oct 10, 2007
- The thinners are by Charlie Jones on Oct 10, 2007
