If it's blush
Posted by Charlie Jones on Sep 22, 2007
and you try to sand it, it'll clog your sand paper with a wax like substance- it isn't really wax.
Just use a scotch brite pad and some plain water to scrub it down. Shouldn't take more than ten minutes to do the whole boat. Dry it off with a towel and then try to sand it.
After that it should sand clean, then another coat will go on fine.
The other reason for a satin rather than a glossy look is humidity changes from when you put it on until it cured. Like it got damper. If that's it, it'll sand right off.
Blush isn't all that big a deal. Many make it out to be, but it's so easy to get rid of it isn't that much problem.
In Response to: I'm blushing by derik s on Sep 22, 2007
- Re: If it's blush by John Beck on Sep 24, 2007
