Re: leaky boat
Posted by Darryl on Sep 19, 2007
How does it look from the inside? From the pictures it looks like the joint is leaking but with the hull paint it is hard to tell where the stains start. Unless you sanding through the cloth and the 2-3 coats of epoxy, I can only think your epoxy hadn't hardened or adhered correctly. The hatch discoloration points me into this direction. How many coats of epoxy did you put on the hull & deck? (Very light colored boat)
In Response to: Re: leaky boat by Russ on Sep 19, 2007
